Support for 1-bit and 4-bit DRAM chip testing (e.g. 41464)
Hi there,
Are there any plans to support older 1-bit and 4-bit RAM chips like 4164/4464/41464 etc.?
I believe it will be pretty easy to implement this in TL-866ii software but super-useful for many users, as these chips still exist in many older devices that need a desperate repair.
Currently we need to go to dedicated hardware solutions just to check a couple of these or similar type of older RAM chips which is a waste of money and space. Implementing this on TL-866II/T56 will for sure boost your sales further!
I hope we can have some good news on this matter in one of your next versions of the XGPro software.
Thanks,
Ioannis
Hi Albano,
Here they are:
Good suggestion, I will post it then also on the Logic Test  ...
sokratis 发表于 2022-4-6 17:32
Hello Ioannis,  :-)
Hi Albano,
Here they are:
https://www.silicon-ark.co.uk/da ... xas-instruments.pdf
https://www.jameco.com/Jameco/Products/ProdDS/41574.pdf
Good suggestion, I will post it then also on the Logic Test section.
Cheers,
Ioannis
Hi there,
Are there any plans to support older 1-bit and 4-bit RAM chips like 4164/4464/41464 etc ...
sokratis 发表于 2022-4-6 08:30
Hello Ioannis,
                    Can you, please, post the address for those old chips datasheets? Nice to have, if available :-)
Maybe on section Logic Test--Thank users for enthusiastic sharing - XGecu Programmer Forums - Powered by Discuz!
would be better to post.
Regards
