Please HELP me with Sharp LH28F320BJE-PT
Hello.
I have Sharp LH28F320BJE-PT
Flash Memory 32Mbit (2Mbit x 16/4Mbit x 8).  I can read it, I can erase it, BUT i can't programm it.
Here is my log
APP Version : 11.60   Model : TL866II Plus
     Device : LH28F320BJE-PT @TSOP48
Pins Detected Passed!
ID: 0x00B0 00E2......OK!
Programming FLASH ...
Programming  ...Failed
I've tried different IC types and find out that if I select LH32F800BGE-B (512Kbit x 16).  I can programm the first 512Kbit of this flash and I've checked, the data is OK.
Please help me!
回复 7# ancc78
   I bought a sample for testing, there is no problem
Hello. I've checked v.11.70 and the problem still exists. Can you tell me if this problem will be fixed next version, or I have to go and buy another programmer?
Hello. Is it possible to solve my problem?
I've checked several flash chips. I think this is can't be a adress pin problem, because  can read flash wih any problem. Test for pin connection shows no error. Also, I get programm error immediatly when starting to program. I also noticed, that LH28F320BJE-PT and LH32F800BGE-B have different algorithms. The first uses Flash16bit , and the second NorFlash. May be this is the problem?
回复 1# ancc78
Carefully handle the connection of pins and socket pins.
First 512kbits is normal . so bad pins is A18/A19 address pins ?
回复 2# Albano.Matos
   I used V3 (TSOP48/SOP44) adapter(SN001-1) with TSOP32/40/48 adapter (SN003)
Hello.
Flash Memory 32Mbit (2Mbit x 16/4Mbit x 8).  I can read it, I  ...
ancc78 发表于 2021-11-13 14:03
Hello,Please post the adapter you are using, V1base, V2 base, other?
