EV1527 OTP Encoder 8Pin
Hello
I need help to copy and program this chip.
this belongs to an electric gate remote control, also these controls are used in arduino modules for RF Receiver and Transmitter  433Mhz, 315Mhz, among others, Remote Control...
Manufacturer = [Silvan Chip Electronics Tech.Co.,Ltd.  http://www.sc-tech.cn ]
Attached Data Sheet for EV1527 OTP Encoder. (Compatible: EV1527, RT1527, FP1527, SC1527, SCL527)
Low standby current: 1.0uA
Wide range of operating voltage: Vcc = 3.0 ~ 12V
Size 20 bits X 4
Same EV1527 different pin configuration
Manufacturer = SILVAN [Silvan Chip Electronics Tech.Co.,Ltd.  http://www.sc-tech.cn ]
Attached Data Sheet for SC2240B
Size 20 bits x 4
all help very well received
This is optional, same purpose, in case you would like to expand, the catalog with OTP Encoder...
Chip Model Most used...
[2240] PT2240
[2241] PT2241
[2260] PT2260
[2262] PT2262 / M3E
[6010] HT6010 / HT6012 / HT6014
[H600] HT600 / HT680 / HT6187 / HT6207
[5326] AX5326
[4134] MC1450XX/ SC4134X
HCS301 / HCS300 / HCS200
FP527 / HT6P20B / HT6P20D
