TL866
I asked you to add Altera EPC2 and EPC1 in support list ...  EPC2LC20N
If you don't able to make it as soon as possible: sent me please the manual or instructions how can I make by myself... I'm able to write some codes in C++, i think I can add the EEPROM by myself using something another EEPROM that already in support list
Thanks, I will wait for it. When are you going to add EPC2 approx?
回复 6# komintern
There is no time to add EPC2 recently, you can buy it after supporting it
回复 5# admin
Admin, thank you for your support, so I need to buy T56 and wait when EPC2, EPC1 Altera will be added is support list of T56? Am I correctly understood? Can I make an order to buy T56 here?
回复 4# komintern
TL866 can not support it , add it on T56 in the future
still no answer  ... Hello admin! I need your help
Yes, thanks, I have read the datasheet and know that EPC2 able to be read and written to through the JTAG interface, but i want to do it with TL866 and 20-pin socket to exclude any wrongs or damages. I will try JTAG if there will be no answer from Admin)
If you don't able to make it ...
komintern 发表于 2021-7-30 18:06
Hello
Manufacturer: Altera®
Part number: EPC2LC20N
I attach the datasheet of the EPC2LC20N
EPC1 Is NOT Reprogrammable
EPC2 Yes it is Reprogrammable!
If you use Atmtel chip configuration which is the same PLCC20 socket
you could damage your programmer
The ALTERA can send VCC through pin 18 not contemplated in the ATMEL configuration even if they are the same PLCC20 socket, be careful !!!
The EPC2LC20N chip has compatibility (ISP) allows you to program ISP-capable Altera® devices through the IEEE Std.1149.1 JTAG interface.
You must wait for the administrator to give you a recommendation ...
