XGecu - Logic Test Error
I found an error in the program while testing logic circuits.  After performing the test, the screen does not refresh its contents with the layout list.  I made a video showing this.
Yovish
Thank you!
回复 7# yovish
we will fix this bug in WIN XP
There are several reasons for this, but mostly because Windows 7, 8, and 10 make a problem with the programs I use.
It's old known bug in this and other software on winXP. What reason use win xp in 2021? I many time stay in winXP but in this time its no sense. If you close logic test window and open again all working again. Its not critical bug and any lying off customer are not detected.
1. Programmer Overview
1.1 Performance Introduction
Carefully built low-cost professional programmer, high-density chip production process, a unified user interface, easy to use, functional integrity, application software, reliable operation, code small, faster execution. supported operating system:
WINXP WIN2003 WIN2008 VISTA WIN7 WIN8 WIN10 32-bit or 64-bit operating system
Win XP support, that was the reason I bought this programmer.
Then it's lying to the customers.
Time to upgrade)
Windows XP Professional  SP3 x86 (32-bit).
What system you are using? In win7 x32 dont have this bug.
