» can add ..H27UCG8T2FTR
来自
Usa
227 小时
公共组
发表于 2021-1-20 02:08
Please...
add support for NAND ...
H27UCG8T2FTR...
I
did not find it in the list
来自
Usa
227 小时
公共组
发表于 2021-1-29 14:57
here is the datasheet
For
H27UCG8T2FTR
H27UCG8T2BTR-BC pdf, H27UCG8T2BTR-BC description, H27UCG8T2BTR-BC datasheets, H27UCG8T2BTR-BC view ::: ALLDATASHEET :::
H27UCG8T2ETR Datasheet - 64Gb MLC NAND Flash Memory - DataSheetCafe.com
Good luck :)
发表于 2021-1-20 12:11
do you have the data sheet?
you have a test with custom Parameters:
(14.7 KB)
2021-1-20 12:10
