IC Request: MCM68766 / MCM68764 / MCM68365
Some longer explanation:
In the 80ies many laboratory gear (like Tektronix and HP) used the Mostek MKB36000 masked ROMs.
The MOS2364 masked ROM was used by commodore.
These ROMs suffer from ROM rot and have a very unique pinout. The MCM68766 is a direct replacement EPROM for all these ROMs.
So supporting these EPROMs could help to repair these instruments without modifiying the original hardware
The MCM68364 and MCM68365 are nearly identical sister-models.
http://bitsavers.trailing-edge.c ... rmware/MCM68366.pdf
https://datasheet.datasheetarchi ... /Document249298.pdf
https://datasheet.datasheetarchi ... -110/DSAP005713.pdf
By the way: The T56 is a great programmer!
Thanks
Holger
Hi!
I understand the reasons.
Thank you very much for the answer.
Holger
This kind of chip is too old. It's not easy. Samples are hard to find.
We do our best to support it.
Here is a link to the MCM68766:
http://bitsavers.org/pdf/ibm/system23/firmware/MCM68766.pdf
Holger
