Please add support of 27C322/160/800/400 EPROM
Hello!
Is it possible to add support for these types of ROMs - 27C322/160/800/400?
There is such an adapter for manually flashing such ROMs in TL866 - https://github.com/mafe72/27c160-tl866-adapter
![](https://github.com/mafe72/27c160-tl866-adapter/raw/master/images/adapter_in_use.jpg)
![](https://github.com/mafe72/27c160-tl866-adapter/raw/master/images/front_th.png)
![](https://github.com/mafe72/27c160-tl866-adapter/raw/master/images/back_th.png)
To flash these ROMs in TL866 using this adapter, you must select the type of ROM 27C4096, manually divide the ROM image into the required number of parts in third-party software and manually flash each part selecting needed part by switch on adapter. it is not comfortable!
Is it possible to use the ICSP connector to use the additional three bits of the ROM address bus?
Thank you!
Sincerely,
Oleh, aka solegstar. |
