Windows Driver ARM Support
i run into a problem - my main workstation is a MacBook M1 on Apple Silicon running a Windows 10/11 ARM Version in a Virtual Machine.
Unfortunately the driver that comes with the T56 won't work here - i can install the driver but once i connect the programmer it can't find any drivers to install.
Either running a manual Driver Install will not find the previously installed Driver.
So my question is, would it be possible to compile and publish beside the X86 and ARM64 Architecture also a driver that supports ARM based architectures? Or do you guys know a solution for my Problem?
I think this would be a great improvement, since nowadays virtual machines have become more and more popular.
Thanks! |
