add new chips in supported list
I need to read from and write to for the next list of chips:
1 - NECD8255AC-5,
2 - NECD8251AFC,
3 - TOSHIBATMP8253P-5,
4 - TOSHIBAТС5565APL-15,
5 -MITSUBISHI M5L8259AP
but i didn't find them in the list. Isit possible for you to sent me any updates for software? I’m using TL866II Pluswith TL866II Plus software v10.29
hello again, could you add also these chips:1 - GD75189A and GD75188
2 - N8T96N, N8T95N
3 - SN7404N, SN7405N, SN7410N, SN7430N
4 - P8284A
5 - SAB8288AP
6 - M5832 (OKI)
7 - DP8304BN
8 - HD3-4702-9
I need it only to make test of them, I can pay for this, i need it ASAP. How much should i pay and when will you be able to sent me updates?
Ответ 2 # админ Thank you, so can you make something just to make settings and test that chips with my device? As you sayed they can be only tested - so that's would be such what i need. Is it possible for you to make some update for software to be able to check them? I need to test them and to compare with the well working one's. All 5565 are working normally - it's not ASAP but preferentially too
回复 1# SergeyCherkasov
      1 - NECD8255AC-5,
2 - NECD8251AFC,
A: above , all is logic IC . no data can be programming and saved. only setting and testing logic if supported.
B: TOSHIBAТС5565APL-15,  this a  SRAM  chip. Power off, data will be lost
