Sandisk SD5C25A-8G/16G eMMC BGA169 Support
Can you add Sandisk SD5C25A-8G SD5C25A-16G eMMC BGA169 Support please.
I tried auto init SD5C25A-8G No success.This chips most used in smartphones. Honor, Mate, etc... Also often used as common flash memory.
good solution
May I know what adapter is
Thank You. You 100% right. I replaced capacity on my adapter to 15pf and now I can read/write succesfully. Thanks.
I got 2 samples.SDC25A-8G
Result tested:   no problem
check your adapter's C10 on top of PCB,  Some sellers have wrongly soldered a capacitor C10.
The correct capacitance is 15p. They used a 0.1uf.
There should be same as  others. I'll get samples to test
