27c322 bug ?
I have a T56 and some 27c322 are not programming correctly.
- The chips are fully erased, blank checked OK.
- Programming step goes well.
- Verify check tells me there is differences with binary image.
The same chip program OK on a Wellon VP280.
I also cross checked: programmed by VP280 are verified OK by T56; and programmed by T56 are both verified as ERROR on T56 and VP280.
I have another batch of 27c322 that is ok and program well on both.
Maybe a problem in settings or algorithm ?
Regards
回复 4# Rom1
The production date of this 27C series chip is relatively early, and the original factory seems to have stopped production, which may be related to the internal charging circuit of the chip during programming.
Changing pulse time didn't work.
Reducing VDD was a success. How can you explain that both reducing and increasing VDD helps ?
Thanks a lot !
Thanks for your help.
I'll already tried changing pulse to 100us with no success.
Yesterday I pushed VDD write to 6.5v and every chip is programming right with only this change.
I'll give a try to both 200us and VDD 5.5v and keep you informed.
回复 1# Rom1
Please try to change Pulse Delay time  from 50us to 200us.
or change VDD write: 6.25V->5.5V testing
