On version 11.80, EMMC projects saved in version 11.20 are not loaded
Help me please!!!  I can't load on version 11.80 projects that were saved on version 11.20.  If I install version 11.20, then the project loads.  But in this case, the T56 programmer does not work.  If I install version 11.80, then the project does not load, but the programmer works.  What needs to be done to load the project from version 11.20 to version 11.80?
回复 1# Vyacheslav
Sorry, a bug was found on the project of version 11.20. then the project cn not be loaded normally.
You can delete the project file .mpj (do not use project) , choose the data folder  by yourself.
