AM29F016B TSOP40 / 48
Hi there! I have a T48 programmer and adapter adp_f48_ex-1 (for a flash drive).
I have problems with the Am29F016B (TSOP48) chip, there is one in the supported list, but marked as TSOP40. The purpose of their contacts is almost the same, in TSOP48 the first two pins do not work. Can I edit the existing profile for the Am29F016B TSOP40 to use the 48 pin IC? Or can you add support?
回复 1# Famicombro
   OK ,we will add it (48-Pin Standard TSOP)in next upgrade for T48 programmer
