Plz Add KFG1GN6W2D-HIB6 BGA63
[اقتباس] الاختبار صحيح وسيتم إضافته في الإصدار التالي.
ECC تعطيل / تمكين دعم برنامج
OTP ... تم
نشر المشرف في 2021-8-28 11:56 [/ quote]
Big thx
you are the best
The test is correct and will be added in the next version.
ECC disable/Enable support
OTP programming support
回复 3# Steve007iii
I have bought some samples, try my best to support it in the next version
At the same time will support Similar ONENAND models:
KFG1GN6W2D
KFG1G16Q2M-DEB6
KFG1G16D2M-DEB6
KFG1G16U2M-DIB6
KFH2G16Q2M-DEB6
KFW4G16Q2M-DEB6
KFG1216Q2M-DEB
KFG1216D2M-DEB
KFG1216U2M-DIB
KFG5616Q1A-DEB5
KFG5616Q1A-PEB5
KFG5616D1A-DEB5
KFG5616D1A-PEB5
KFG5616U1A-DIB5
KFG5616U1A-PIB5
KFG2816Q1M-DEB
KFG2816D1M-DEB
KFG2816U1M-DIB
回复 2# admin回复 1# DjamelGsm
I need to program KFG1GN6W2D OneNand with T56.
Can You please add support ?
Regards :-)
tertomium 发表于 2020-8-2 19:42
This order is duplicated
Samsung OneNand KFG1GN6W2D
Samsung OneNand KFG1GN6W2D support
We cannot find any reference of this chip number, please attach the chip datasheet or photo to deduce the real number...
It is the closest thing I found to a Samsung chip to the description given by the user...I'm not sure but I think it refers to the KFG1G16Q2M
Please send a photo of your chip to be sure...
Part number description: K F G  1G  N 6  W 2 D - H I B 6  X XX
Part number description: K F X  XX  ?  X  ?  X X - ? X X X X XX
W = Vcc :with this reference table the w is unfinished
Generic Samsung encoding
K Memory
F OneNAND Flash
X Small ClassificationD = De-Muxed w/o RDY
E = De-Muxed 2 die stack w/o RDY
G = De-Muxed
H = De-Muxed 2 die stack
K = Muxed 4 die stack w/dual nCE
M = Muxed
N = Muxed 2 die stack
W = De-Muxed 4 die stack w/dual nCE
XX Density12 = 512M
28 = 128M
56 = 256M
1G = 1G
2G = 2G
4G = 4G
8G = 8G
X Technology1 = SLC
M = MLC
H = Hybrid
X Organization6 = x16
X VccD = 2.5V/2.7V (2.4V to 3.0V)
Q = 1.8V (1.7V to 1.95V)
U = 3.0V/3.3V (2.7V to 3.6V)
X Mode0 = 512 byte page
1 = 1K byte page
2 = 2K byte page
4 = 4K byte page
X GenerationM = 1st generation
A = 2nd generation
B = 3rd generation
C = 4th generatio
D = 5th generatio
X Package TypeF = FBGA
D = FBGA (Lead-free)
L = ULGA (Lead-free)
M = FBGA (Lead-free, SAC105)
N = FBGA (Lead-free 35)
Y = TSOP1
P = TSOP1 (Lead-free)
S = FBGA (Lead-free, special)
C = Chip BIZ
W = Wafer
X Temperature RangeC = Commercial
E = Extend
I = Industrial
0 = None
X Bad Block0 = None
B = Include bad block
D = Daisychain sample
X Speed0 = Reserved
5 = 54 MHz
6 = 66 MHz
8 = 83 MHz
X Packing TypeT = Tape&Reel
0 = Other (Tray, Tube, Jar)
S = Stack
P = Module Tape&Reel
M = Module other packing
XX Customer
回复 1# DjamelGsm
I do not find the data sheet of this chip.  only add after getting the data sheet.
