Tab " Logic IC"
Is it possible to expand the "LOGIC IC" tab with new layouts?
In the TL866 programmer
In this tab, a lot of systems are missing, e.g. 40106
Hello again, could you add also these chips:
1 - GD75189A and GD75188
2 - N8T96N, N8T95N
3 - SN7404N, SN7405N, SN7410N, SN7430N
4 - P8284A
5 - SAB8288AP
6 - M5832 (OKI)
7 - DP8304BN
8 - HD3-4702-9
I need it only to make test of them, I can pay for this, i need it ASAP. How much should i pay and when will you be able to sent me updates?
I am currently implementing a freely extendable logic test for the TL866IIpro using the minipro Open Source project as base and I'm looking for testers.
The test vectors can be freely configured or you can use an existing database of test vectors.
It also supports testing of PAL/GAL/ATF chips. For this you need to provide the .si and .sim file you already use for the software simulator.
When I looked it up correctly, the logic and pins of the 40106 is identical to 7404 (6x inverting driver), only the voltage is different?
Drop me a message when you are interested.
  Michael
回复 1# Test
There will be difficulties in increasing ON TL866II.
User-defined functions about Logic ICs  will be realized on T56 in the future.
