KM28C64A fails programming
Samsung KM28C64A fails programming - Buff value 0xC3, Chip vvalue 0xFF.
I don't understand your answer. I tried every 28C64 in the library - none work. You list the KM28C64 ...
stevemas 发表于 2022-3-20 02:06
I means, your chip may be IC relabeled . so hope test by others.
    As an user....  Sometimes, when order new ICs, they are not new, some are sold defect, or are relabeled to look other reference.
The main result, most of times, if they are indeed close specifications, it is a different IDs problem that can be
easily ignored removing CHECK ID, but sometimes is something else.
What Admin ask you, if i understand well ( due to errors ) is if you have the opportunity to test with other
xx2864xx ICs , not the KM28C64A you have? ( i understand that you test four ICs with that reference, all gave same
error in result)
Are your ICs new? Recently ordered, or part of an old stock?
Have you an older programmer, to also test  there those KM28C64A you have?  ( as the ICs are a bit old)
KM28C64A pdf, KM28C64A Description, KM28C64A Datasheet, KM28C64A view ::: ALLDATASHEET :::
I am sure, if there is a bug in the app for this IC, Admin will fix it soon for you, if time and patience is available, hopefully
I don't understand your answer. I tried every 28C64 in the library - none work. You list the KM28C64A but this does not work either. I have tried 4 chips. All fail. I am not sure how you can say you support the KM28C64A if it fails. Have you tested your software with this chip or do you assume it should work? Perhaps I should return this programmer as it is useless for my operation.
回复 5# stevemas28C64 all is same.  but they have diffrent page size.
genuine product KM28C64A page size is 64.  KM28C64  page size is 32.
AT28C64B(Non-Standard)  none page
AT28C64F   none page
you can test more with duffrect xx2864xx.
dip-28APP Version : 11.81   Model : TL866II Plus
     Device : KM28C64A
Pins Detected Passed!
stevemas 发表于 2022-3-19 11:17
         Ensure that latest version of Xgpro is in use .
As i cant test this IC , do not have a sample ....
It seem, without any special order, you may have a faulty IC, a software bug, other hardware failure.
Hopefully ADMIN will help further with another tip, or correcting the problem :-(
     Device : KM28C64A
Data Protect Disable...OK!
Programming FLASH ...Succeeded. Time : 1656ms
Verifying FLASH ...
ERROR!   CODE Address:0x000000    Buf_Val:0xC3    IC_Val:0xFF
Programming  ...Failed
My chip is a Samsung KM28C64A.
I tried CAT28C64A, log below:
APP Version : 11.90   Model : TL866 ...
stevemas 发表于 2022-3-18 01:42
   As an user.....Is your IC DIP or PLCC32 Package. If PLCC package, which adapter are you using? Please post a photo inserted the way you are using. Thank you
APP Version : 11.90   Model : TL866II Plus
     Device : CAT28C64A
Programming FLASH ...Succeeded. Time : 3062ms
Verifying FLASH ...
回复 1# stevemas
is your chip is KM28C64A?KM28C64A is diffrent with KM28C64
you  try to  choice CAT28C64A  programming it .
