TL866II Plus problem with Eeprom XR2808
I have a problem with the TL866II plus programmer.When I try to read the XR2804 chip is reported "Bad pin found" relatedto pin 22 and 19 . I tried different chips but the problem remains.I have the same problem using the T48 programmer. Do you have a solutions?
Thank you
Giangiacomo
I have a problem with the TL866II plus programmer.When I try to read the XR2804 chip is repor ...
Elektron 发表于 2023-5-30 00:28
   As a User,                  Have you tried to do the read with 'pin detect' unselected
(bottom left in XGPRO, inside options pane)?
Try it, please, and post here what you get. Maybe an error, Admin will tell
about it.
I tried to exclude pin detect but every time I read the memory it generates a different ChkSum!!?
Thank's
