PIC 12F629 Does Not Work with T48 Programmer (XGpro v12.63)
| I am also having problem with PIC 12F629. I am using latest XGpro software v12.63 . I have purchased two "new" IC's and the T48 cannot program either one. When I attempt to program the IC, the XGPro software clears all flags and memory by putting 0's (zero) in the contents. Program Memory = all 0's. Data Memory = all 0's. Config Word = all 0's. When I try to perform ERASE function, it does not work. Everything remains 0's. Note that a blank chip should have all F's instead. I noticed you have 3 other forum discussions on this same topic. Therefore, I will post this message 3 times. I can't tell you how much time and effort I and other have wasted on this. Will Probably have to buy a Microchip PicKit instead, because I cannot wait for you to release your next version of XGPro. Thanks. |
