V13.25 for T76- Software and IC support List are here soon xgecu.
1. Supported Quantity: 42945, 300+ New Additions
.     Added Octal chips: MX25LM256, MX25UM256/512/513 series
.     S70FL01GS series
.     S70GL02G series
.     MT28FW02G
.     SP25WD40A/SP25WQ32A
.     MT25QU512ABB
.     MX35LF1GE4AD
.     XT25BF256BW
.     PIC C series chips added
2. Added configuration registers for some 25-inch Flash chips
3. Fixed AT28BV64B/256B programming algorithm
V13.16 for T48, T56, and TL866II - Lists  and software are here soon
xgecu.
1. Added support for hundreds of chips
2. Fixed known defects
Supported Chips:
TL866II-.19740 from 19550 from 19353 from 19336 from 19326 from 19272 from 19023 from 18991
T48-----.37103 from 36377 from 36029 from 35993 from 35969 from 35779 from 35267 from 35138
T56-----.40039 from 39687 from 38850 from 38811 from 38783 from 38537 from 38062 from 37906
T76-----.42945 > 42621 > 42276 > 41190 > 40093 > 39659 > 39009 > 38649 > 38540 > 38319 >  36111 > 35186
(TO Admin: Please fix T56 issue with all current in sale BGA153/169 Adapters, for IC H26M62002JPR, as it fail to initialize. This IC only work with Xgecu high speed adapter, but is discontinued, or at least give a tip to correctly rework those failing adapters.
Some requests from users in the forum, not yet fulfilled. Please, if you can, add them to be available:
T56-PALCE22V10Z_ PLCC28&DIP/SOIC24
T56-MBM29F080 SOP44
T56-FL128SAif00
T56-MTFC16GAPALNA-AAT
T48-w78e58b
T48-LH28F160BJD LH28F320BJD  DIP42
T76-at89lp51ed2-20pu
T76-PM37LV512
Best Regards )
V13.19 for T76
.   C. Other chips
3. Fixed known bugs
V13.16 for T48, T56, and TL866II - Lists  and software are here soon xgecu.
Supported Chips:
(TO Admin: Please fix T56 issue with all current in sale BGA153/169 Adapters, for IC H26M62002JPR, as it fail to initialize. This IC only work with Xgecu high speed adapter, but is discontinued, or at least give a tip to correctly rework those failing adapters. Best Regards)
12.93
Good News, new T76 only software version is out. Now support 38540 ICs, list  and software is here xgecu
12.95
6. Fixed some known BUGs
Hello ,
T48--- ...
12.93
Hopefully, get it done.
lists, you can downl ...
Hello ,
Latest translated changes:
T76: 12.91.
12.91
12.89
3. Fixed known BUGs
12.85
3. Known BUGs have been fixed
T48-56-TL866II-12.90
12.90-12.88
1. Chip support quantity:
T56: 38537
TL866II: 19272
T48: 35779
12.78
T56 programmer:
Support: 37906 (+150)
T48 programmer:
Support: 35138 (+142)
TL866II programmer:
Support: 18991 (+75)
3. Fix known defects
FM28V020, 8582 fix
ATMEGA8A EEPROM Erase fix
12.67
T56 programmer:
Support: 37756 (+105)
T48 programmer:
Support: 34996 (+86)
TL866II programmer:
Support: 18916 (+26)
2. Newly added:
ZB25Qxxx
XM25RU128C
D27C011
and other chips
3. Fixed known defects
TMS27C240 fixed
AK6440AM AF fixed
Fixed other known bugs
12.66
Version: V12.66 2024.2.5
T56 programmer:
Support: 37651 (+158)
T48 programmer:
Support: 34910 (+120)
TL866II programmer:
Support: 18890 (+65)
and other chips
Test 发表于 2025-4-18 09:11
TL866II-.19023 from 18991
T48-----.35267 from 35138
T56-----.38062 from 37906
T76-----.36111 from 35186
liuyunx 发表于 2025-2-11 21:01
Gabo 发表于 2025-1-8 21:26
Where are the updates?
Hi, Please add Xicor X24645
tytka 发表于 2023-10-5 16:17
Dear Admin, please help!
Ответить  администратору
Здравствуйте.Как прочитат ...
bekso 发表于 2023-8-27 23:58
Hope it helps, or not :(
Reply  admin
    As a user,
回复  Albano.Matos
ADP:TSOP32  one by one
admin 发表于 2022-11-2 14:25
版本:  V12.35  2022.10.31
T56编程器 :
Support: 34791+758
T48编程器 :
Support: 32086+748
TL8 ...
admin 发表于 2022-10-31 13:43
Rgds
王老吉 发表于 2022-6-2 20:24
Hope it Helps
