does
someone answer gavinbx Posted on 2023-11-30 11:32
As a User, You can try, starting Xegu application without any programmer connected.
Select T56, choose the IC you need, enter it and verify device info. Close the program
connect the programmer and start the app, it will in both cases show now the correct
adapter for T48.
I think, this is a flaw in the software, i'm guessing.
Hopefully it will be solved in the next version of software that i feel a complete new version
with all those annoyances solved, or not :(
Hope it helps, if it works ok, is a workaround not a fix as i do not have the T48 or the proper adapters to check. :) |
