I asked you to add Altera EPC2 and EPC1 in support list ... EPC2LC20N
If you don't able to make it ...
komintern 发表于 2021-7-30 18:06
Hello
Manufacturer: Altera®
Part number: EPC2LC20N
I attach the datasheet of the EPC2LC20N
EPC1 Is NOT Reprogrammable
EPC2 Yes it is Reprogrammable!
If you use Atmtel chip configuration which is the same PLCC20 socket
you could damage your programmer
The ALTERA can send VCC through pin 18 not contemplated in the ATMEL configuration even if they are the same PLCC20 socket, be careful !!!
The EPC2LC20N chip has compatibility (ISP) allows you to program ISP-capable Altera® devices through the IEEE Std.1149.1 JTAG interface.
You must wait for the administrator to give you a recommendation ... |
