标题: ROSATOMFLEET [打印本页]
作者: SergeyCherkasov    时间: 2020-9-19 01:11     标题: ROSATOMFLEET
hello again, this is first priority:We need to check with TL866 II the next chips:
- DP8304BN
- D3-4702-9
- SAB8288AP
- P8284A
- N8T95N
- N8T96N
- SN74LS368AN
- SN74LS365AN
- M5832 (OKI)
I repeat, I can PAY you for this job if you asked. We need it ASAP because this list for atomic icebreaker "Varzuga"!
my e-mail: sergey.cherkasov@ru.abb.com
Answer me on my e-mail please ASAP.
The most rest chips we have checked well by using yours device (TL866II - good device really, thanks).
I think you will choose this as a first priority, because this is for atomic icebreaker.
作者: SergeyCherkasov    时间: 2020-9-24 15:13
Hello anyone??? Is there will be any feedback or not?? This is 5 minutes work for making IC tests of that list, is that a big problem for ypu??? If it is then give me the instructions how to write pgrogram for IC test!!
作者: admin    时间: 2020-9-25 12:26
Adding the test of logic chip, there is no time to do it now. In the future(in next month), we will use the user-defined function. Use the vector table for testing. You can add the test function yourself.
作者: SergeyCherkasov    时间: 2020-9-25 14:15
Hello, so, if i correctly understood: you are going to make an update, where users will be able to add new chips and add new algorytms for them? Because now i tried to ADD NEW CHIP but nothing results.
作者: SergeyCherkasov    时间: 2020-9-25 14:23
Untitled.png this function now doesn't work, could you describe how exactly should I adding new chips (now it's just copying reference chip with a new name and nothing , I can't change the program test logic)
图片附件: Untitled.png (2020-9-25 14:22, 33.62 KB) / 下载次数 19867
http://forums.xgecu.com/attachment.php?aid=177&k=4d5356d2ec5fa06c56b82d5cea5ac9ed&t=1793379697&sid=ZoUn75
作者: admin    时间: 2020-9-25 15:28
回复 5# SergeyCherkasov
this is only for memory flash.logic IC testing be not ready yet.
作者: SergeyCherkasov    时间: 2020-11-6 21:09
hello again, We need to check with TL866 II the next chips:
- DP8304BN
- D3-4702-9
- SAB8288AP
- P8284A
- N8T95N
- N8T96N
- SN74LS368AN
- SN74LS365AN
- M5832 (OKI)
How long should I wait for this? If you have a little time then give me the instructions how to add it by myself?? I really need DP8304BN, SAB8288AP, P8284A, N8T95N, N8T96N, SN74LS368AN, SN74LS365AN.
I have been waiting for 4 months allready!!!
作者: admin    时间: 2020-11-7 13:19
图片附件: TTL.jpg (2020-11-7 13:19, 72.97 KB) / 下载次数 19941
http://forums.xgecu.com/attachment.php?aid=200&k=7216aabbb860da80e64e8ae02dcd4da7&t=1793379697&sid=ZoUn75
图片附件: TTL2.jpg (2020-11-7 13:24, 74.39 KB) / 下载次数 20026
http://forums.xgecu.com/attachment.php?aid=201&k=8ee03aeaee35f76b64abe7c49019809f&t=1793379697&sid=ZoUn75
作者: STALKER_71    时间: 2020-11-8 08:01
Varzuga is tanker, not icebreaker
作者: SergeyCherkasov    时间: 2020-11-12 21:36
thank you. I think I will be able to test by myself 8304BN, but i still need help with SAB8288AP
and P8284A. What about them? It's not an IC logic (probably) (there are drivers for 8086 processor)
作者: admin    时间: 2020-11-14 16:50
回复 10# SergeyCherkasov
Logic testing  only test  simply logic chip. Other types of chips can not be tested.
作者: SergeyCherkasov    时间: 2021-5-12 17:25
Thanks, all i need is done)
