标题: Please Upgrade Programmer TLL866 II [打印本页]
作者: Tricky    时间: 2023-2-3 10:39     标题: Please Upgrade Programmer TLL866 II
I'm trying to program AMD 2732B chips (Vpp is 12.7V) and they are failing at the first byte.
My model programmer fails while your earlier and later programmers work.
It's a very simple fix for you, please just spend a moment on it.
The fact the programmer only goes up to 18V programming and most 2732 require 21V maybe why you've ignored fixing it?
But you have low voltage 12.7V program 2732 chips and there's no reason that programmer shouldn't support it.
Please fix this.
