标题: Nand Flash Edit Buffer MX30LF1G18AC [打印本页]
作者: fabiod    时间: 2020-9-15 16:13     标题: Nand Flash Edit Buffer MX30LF1G18AC
I read Nand Flash MX30LF1G18AC in the default file
Flash_data.bin
then I want to Edit Buffer for changing one or more words...like in picture
but when I save the new file modified...
this is the result...
the size is only 133kb and I can't use this file
for programming the New IC Blank Nand Flash...
How Can I resolve this?
Thanks
图片附件: 1.jpg (2020-9-15 16:09, 429.57 KB) / 下载次数 12438
http://forums.xgecu.com/attachment.php?aid=165&k=98574e433355134d27439e0b58c21622&t=1793214943&sid=6y8v62
图片附件: 2.jpg (2020-9-15 16:11, 118.57 KB) / 下载次数 10908
http://forums.xgecu.com/attachment.php?aid=166&k=111fb76ddfaa9777941324635219ffa2&t=1793214943&sid=6y8v62
作者: fabiod    时间: 2020-9-16 20:57
I solved it...I opened file with hex editor...then I modified bin file...
and I saved the new file...
then I loaded file in the XGECU software...
and it works perfectly....
