标题: How to read this W25Q64FV@TFBGA24 (WINBOND)? [打印本页]
作者: frankviana    时间: 2022-12-18 06:44     标题: How to read this W25Q64FV@TFBGA24 (WINBOND)?
No way to read this chip too...
WINBOND (TFBGA24)
W25Q64FVCIP
https://datasheet.lcsc.com/szlcsc/W25Q64FVSSIGE_C14067.pdf
PAG 09 (DATASHEET)
I'm using this adapter:
https://pt.aliexpress.com/item/1 ... atewayAdapt=glo2bra
Please tell me a way to read..
Thanks
作者: admin    时间: 2022-12-18 08:13
回复 1# frankviana
   use a BGA24->DIP8 adapter  and select a 8pins IC
作者: Albano.Matos    时间: 2022-12-18 13:54
WINBOND (TFBGA24)
W25Q64FVCIP
PAG 09 (DATASHEET)
I'm ...
frankviana 发表于 2022-12-18 06:44
   As a user: Can you, please, post a photo from the adapter inserted in programmer, and the print screen from xgecu software, with the results or errors you are seeing?
Rgds
