标题: ATtiny configuration suggestion [打印本页]
作者: Test    时间: 2022-12-9 19:11     标题: ATtiny configuration suggestion
As of now, the configuration bytes are set by checking boxes for each parameter, and then the program calculates the config bytes for you. Would be nice with possibility to do it the other way around too, by simply entering the desired configuration bytes.
See the attached screenshot for an example. If I wanted the depicted configuration, I'd simply enter 7A, F4, FD for low fuse, high fuse, and lock bit respectively in text boxes, instead of checking the parameter checkboxes.
This would simplify things when using an external calculator to calculate the config bytes.
图片附件: attiny.jpg (2022-12-9 19:11, 155.93 KB) / 下载次数 22674
http://forums.xgecu.com/attachment.php?aid=1616&k=b5e582c5cfa4374373b02ddc893b25b1&t=1793323446&sid=25GY2k
作者: dyf2007    时间: 2022-12-9 23:33
其实做成progisp软件那样挺不错,可以直接选择,也可以输入avr单片机保险的高低位数值,感觉这样方便点。
