标题: tl866 II plus device unavailable or error [打印本页]
作者: dahoe78    时间: 2022-11-9 11:51     标题: tl866 II plus device unavailable or error
i installed xgecu1234 also xgpro with all drivers the drivers are great but.... no matter what i try it doesn't open at all even trying to run under another version of windows by the way im running win10 on my laptop. uninstalled reinstalled several times and tried to run under win8 all the way back to xp with no avail. so i then downloaded minipro v6.85 that works but doesnt connect to the programmer it says device unaavailable or error when i do a system self test. at the bottm of the minipro window it says.. hardware interface ver: no device. i also tried mplab software not getting anywhere please help
作者: admin    时间: 2022-11-10 09:31
回复 1# dahoe78
What is the error prompt when you can't open it?
Is the window minimized?(Solve: delete [othercfg.dat] in install folder)
