标题: How to Adjust voltage in SPI mode [打印本页] 作者: TonyD 时间: 2022-10-18 22:11 标题: How to Adjust voltage in SPI mode
Hi, Is there a way to adjust voltage while using SPI mode (in circuit reading)? There are few eeprom's i need to lower/raise the voltage to read and writing and can't seem to find where to change it. There's menu to adjust current, but i need voltage. I have the T48.
Thanks作者: admin 时间: 2022-10-19 09:30
This function is not available yet. we will consider adding this option .作者: TonyD 时间: 2022-10-20 08:34
Important feature for the eeproms i work with, automotive. Some i need to lower voltage to read and can't find a way to do it with T48. Please add function when/If possible. Thank You
