标题: add new chips in supported list [打印本页]
作者: SergeyCherkasov 时间: 2020-8-13 03:29 标题: add new chips in supported list
I need to read from and write to for the next list of chips:1 - NECD8255AC-5,
2 - NECD8251AFC,
3 - TOSHIBATMP8253P-5,
4 - TOSHIBAТС5565APL-15,
5 -MITSUBISHI M5L8259AP
but i didn't find them in the list. Isit possible for you to sent me any updates for software? I’m using TL866II Pluswith TL866II Plus software v10.29
作者: admin 时间: 2020-8-13 13:15
回复 1# SergeyCherkasov
1 - NECD8255AC-5,2 - NECD8251AFC,
A: above , all is logic IC . no data can be programming and saved. only setting and testing logic if supported.
B: TOSHIBAТС5565APL-15, this a SRAM chip. Power off, data will be lost
作者: SergeyCherkasov 时间: 2020-8-13 15:52
Ответ 2 # админ Thank you, so can you make something just to make settings and test that chips with my device? As you sayed they can be only tested - so that's would be such what i need. Is it possible for you to make some update for software to be able to check them? I need to test them and to compare with the well working one's. All 5565 are working normally - it's not ASAP but preferentially too
作者: SergeyCherkasov 时间: 2020-8-14 00:49
hello again, could you add also these chips:1 - GD75189A and GD75188
2 - N8T96N, N8T95N
3 - SN7404N, SN7405N, SN7410N, SN7430N
4 - P8284A
5 - SAB8288AP
6 - M5832 (OKI)
7 - DP8304BN
8 - HD3-4702-9
I need it only to make test of them, I can pay for this, i need it ASAP. How much should i pay and when will you be able to sent me updates?
| 欢迎光临 XGecu Programmer Forums (http://forums.xgecu.com/) |
Powered by Discuz! 7.2 |
