标题: hello.. Can You Add Thins New Chip id AT25SL321 [打印本页]
作者: mohamed    时间: 2020-8-3 21:30     标题: hello.. Can You Add Thins New Chip id AT25SL321
http://www.adestotech.com/wp-content/uploads/AT25SL321_112.pdf
作者: admin    时间: 2020-8-7 16:06
回复 1# mohamed
   AT25SL321 is a 1.8V device . Tl866II is not stable.   you can select a  AT25SF321, and disable "Check ID", and use a 3.3V to 1.8V adapter for 25S.
  AT25SL321 has been supported on T56.
