标题: Samsung OneNand KFG1GN6W2D support [打印本页]
作者: tertomium    时间: 2020-8-2 19:42     标题: Samsung OneNand KFG1GN6W2D support
I need to program KFG1GN6W2D OneNand with T56.
Can You please add support ?
Regards :-)
作者: tertomium    时间: 2020-8-11 04:10
Anyone who can help?
作者: admin    时间: 2020-8-11 12:38
回复 2# tertomium
   Please wait, onenand will join supported soon
作者: tertomium    时间: 2020-8-13 14:43
Thanks for your reply.
Good to hear!
Have a nice day.
作者: ValeryS    时间: 2021-6-22 00:53
Good day. Are you still planning to support this type of memory?
And will it work with the Samsung bad block table?
作者: admin    时间: 2021-6-22 12:27
回复 5# ValeryS
OK
Next month。
作者: admin    时间: 2021-6-26 11:23
回复 6# admin
   KFG1GN6W2D? it is KFG1G16xx?  do you have a data sheet?
作者: ValeryS    时间: 2021-7-28 01:40
KFG1GN6W2D Plz.
作者: Steve007iii    时间: 2021-8-17 14:52
回复 1# tertomium
This order is duplicated  Plz Add KFG1GN6W2D-HIB6 BGA63
作者: admin    时间: 2021-8-28 11:55
回复 9# Steve007iii
The test is correct and will be added in the next version.
ECC disable/Enable support
OTP programming support
图片附件: KFG1GN6W2D.png (2021-8-28 11:55, 51.08 KB) / 下载次数 27024
http://forums.xgecu.com/attachment.php?aid=913&k=89b22a38da57129ce80d07ae1d684ff3&t=1793441664&sid=qOTz3K
