标题: H26M52103FSR Reading Error [打印本页]
作者: lumina    时间: 2022-7-26 05:29     标题: H26M52103FSR Reading Error
What could be wrong? The error log is:
PP Version : 12.05   Model : T56  MFG:2022-03-06
Device : H26M52103FMR_8Bit @BGA153
Pins Detected Passed!
Init EMMC... OK!    ( OCR register: C0FF8080 )
Reading ECSD : Succeeded
Failed  -- CMD No Responed Status: 00000980 Error Code: 1
Switch to USER AREA Error!
The EMMC version is lower, Testing  frequency <= 20MHZ
作者: admin    时间: 2022-7-26 16:24
回复 1# lumina
   Test with 4b or 1b with low speed. (or VCC=3.3/3.3V)
作者: lumina    时间: 2022-7-27 04:08
4 bit and 1 bit same error, 1.8 volts same error, see picture.
Log:
APP Version : 12.05   Model : T56  MFG:2022-03-06
     Device : H26M52103FMR_4Bit @BGA153
Emmc Data DAT0 busy 000A__00000980 Error Code: 1
图片附件: Capture.JPG (2022-7-27 04:08, 201.1 KB) / 下载次数 13556
http://forums.xgecu.com/attachment.php?aid=1325&k=9f613638f17eb2810584704f4816e28d&t=1793404116&sid=0TH5X0
作者: admin    时间: 2022-7-27 08:07
回复 3# lumina
EMMC is bad and is often found,  this is a old chip.  EMMC version is low.
作者: lumina    时间: 2022-7-28 05:44
Is a 7 year old TV but if I can not read the chip, I have to put it in the garbage, main board is more expensive that the TV value. Thanks
作者: Albano.Matos    时间: 2022-7-28 13:08
Is a 7 year old TV but if I can not read the chip, I have to put it in the garbage, main board is mo ...
lumina 发表于 2022-7-28 05:44
   As a User:   In the tv repair business, many times you can order those chips in newer versions, already preloaded with correct software on them, sometimes some friend in a forum post the software and indication of
a newer and equivalent IC, or the bulletin from brand support services....
Like the programmers themself, like TL866II --> 'turns' into T48, T56 will have an upgrade in the future, hopefully,
why not this IC. For sure, is up to you decide the way :-)
