标题: TL866II Plus Self Test Fail on GND Pin 1 [打印本页]
作者: Eddiie    时间: 2022-6-25 01:06     标题: TL866II Plus Self Test Fail on GND Pin 1
I have a TL866II Plus that fails self check, but my other TL866II Plus passes OK. How do I fix GND pins on self check?Thank you!
作者: admin    时间: 2022-7-8 08:17
回复 1# Eddiie
this is a hardware failure. only back to be repaired
