标题: Winbond W25R256JVEQ support [打印本页]
作者: giannino86    时间: 2022-6-22 20:23     标题: Winbond W25R256JVEQ support
Could you please add TL866II support for this IC
Winbond W25R256JVEQ
Package WSON 8x6
Here is the datasheet:
GENERAL DESCRIPTION (mouser.it)
Thank you
附件: [datasheet w25r256jveq] Winbond_Electronics_Corporation_11012018_W25R256JV-1499901.pdf (2022-6-22 20:21, 1.11 MB) / 下载次数 20062
http://forums.xgecu.com/attachment.php?aid=1289&k=8a3ce53613502a9f11495857314de0f3&t=1793649585&sid=n5no9W
作者: admin    时间: 2022-9-29 08:29
Normal flash it is same with W25Q256JV. But it has an enhanced authentication security feature by Replay ProtectionMonotonic Counter (RPMC).  It is a lot of work for the programmer to implement this function. RPMC is protected by security, not much useful for the ordinary user.
Unable to add support it at this time.
作者: 上帝帅气    时间: 2022-10-1 15:28
回复 3# admin
    希望这个也能添加下MX77L12850F
