标题: After firmware upgrade the "check device ID" can't be performed [打印本页] 作者: Bartoloni 时间: 2022-6-18 01:48 标题: After firmware upgrade the "check device ID" can't be performed
I have upgrade XGPRO software today ( to version 12.01 ) after that i received a request to upgarde also Firmware of the TL866II PLUS
during the reflashing the indicators went very slow... (on last 2 years this process was very fast)
after flashing there was a message like "can't restart programmer"
and now i have this issue on "check device id"
there is a way to FORCE a new reflash (maybe using another USB prot with another chipset)作者: admin 时间: 2022-6-18 12:23
回复 1#Bartoloni
reflash it. donot use external USB hub. or do it on another computer.作者: Bartoloni 时间: 2022-6-18 15:40
回复 Bartoloni
reflash it.
The "reflash firmware" is grayed out beacuse the firmware is the latest one ( 04.02.129 ) .. i need to to overwrite it with the same firmware (and i will use a different computer with a different USB chipset)
there is some sort of extra command to force the re-flash??? something like: xgpro.exe /force ???作者: Bartoloni 时间: 2022-6-20 18:37
i need to wait next official firmware upgrade ?
meanwhile i bought another TL866II Plus ... i think this device is very useful and i need it...
there is a way to duplicate the firmware from my new device to the old one?作者: Evcon 时间: 2022-6-20 20:52
Can you take a screenshot of the program after executing the Help-About command on the failed 866?作者: Bartoloni 时间: 2022-6-20 23:02
sure :)
here you are:
the system self-check is also reporting everything NORMAL.作者: Evcon 时间: 2022-6-21 02:48
:( i think i will do a firmware reflash using the DavidGriffith opensources utilities... but i'm little worried about the bootloader or losing the serial number... ican't wait 6 months to reflash with next official update :(作者: admin 时间: 2022-6-22 14:11
Open the cover of the programmer .there is a 6P connector, short PIN2 and PIN5. then plug into USB.
you can reflash now!作者: Bartoloni 时间: 2022-6-22 19:49
Very thank you!作者: Bartoloni 时间: 2022-6-22 20:17
is this the correct pinout?
nevermind... yep, just tried, and the squared one is the 1 :) thank you again for the support!
