标题:
Support for Ramtron FM1808 FRAM
[打印本页]
作者:
vriviere
时间:
2020-7-3 21:31
标题:
Hi, I tried to read a
Ramtron FM1808 FRAM
using "Standard SRAM 61256", but the test failed.
Is it possible to add read/write support for that device?
Here is the
datasheet
作者:
时间:
2020-7-5 17:03
vriviere
OK, it will be added in next version.
作者:
vriviere
时间:
2020-7-5 19:31
Wow, marvellous, thank you.
So I'm looking forward to next version.
作者:
vriviere
时间:
2020-7-12 04:55
I've just tested Xgpro V10.22: it works perfectly! I've been able to read and write my FM1808.
Many thanks for that.
作者:
Mohamed_90
时间:
2022-8-22 03:40
JY 2240 2032
Powered by Discuz! 7.2
