标题: Support for 1-bit and 4-bit DRAM chip testing (e.g. 41464) [打印本页]
作者: sokratis    时间: 2022-4-6 17:34     标题: Support for 1-bit and 4-bit DRAM chip testing (e.g. 41464)
Hi there,
I was suggested to re-post my message in this section as it seems to be more relevant:
Are there any plans to support older 1-bit and 4-bit RAM chips like 4164/4464/41464 etc.?
I believe it will be pretty easy to implement this in TL-866ii software but super-useful for many users, as these chips still exist in many older devices that need a desperate repair.
Currently we need to go to dedicated hardware solutions just to check a couple of these or similar type of older RAM chips which is a waste of money and space. Implementing this on TL-866II/T56 will for sure boost your sales further!
I hope we can have some good news on this matter in one of your next versions of the XGPro software.
Some relevant datasheets:
https://www.silicon-ark.co.uk/da ... xas-instruments.pdf
https://www.jameco.com/Jameco/Products/ProdDS/41574.pdf
Thanks,
Ioannis
作者: yovish    时间: 2022-4-8 15:59
Unfortunately, but logic testing in TL-866II+/T56 programmers, at present, does not facilitate memory testing for several reasons:
1. the maximum number of test lines in the logic vector is 512;
2. lack of instructions for sequential address insertion, each address must be entered bit by bit manually;
3. no additional editing functions in the vector, e.g. deleting single or selected lines, pasting lines, etc, etc.
At the moment, it is easier to make a memory tester yourself using e.g. Arduino, ESP or STM.
I also hope that the company will soon change its mind and quickly add various facilities.
