标题: Support N25Q064A11 for Xgecu Pro ? [打印本页]
作者: lololo    时间: 2022-3-22 18:12     标题: Support N25Q064A11 for Xgecu Pro ?
Hello, why the N25Q064A11 chip is only supported by the Xgecu T56? Because the Tl866-II plus (Xgecu pro) supports the N25Q064A!
Thank you
作者: Albano.Matos    时间: 2022-3-23 15:45
Hello, why the N25Q064A11 chip is only supported by the Xgecu T56? Because the Tl866-II plus (Xgecu  ...
lololo 发表于 2022-3-22 18:12
    As an user....Have you tried to autodetect the IC? Most of times work, and give opportunity to add you the  ICs the way you need.
Press Select IC, then 25 Flash detect, be careful looking where to insert it, give a name and manufacturer, remember that it is numonyx, it was aquired by micron some years ago,  and follow ...   Hope it helps you.:)
If not at latest version of Xgpro (11.90), also try it
Download Newest XGecu T56/TL866II software(下载最新软件) - 编程器使用与软件下载 - XGecu Programmer Forums - Powered by Discuz!
