标题: AT27C4096 55JU [打印本页]
作者: mrt    时间: 2022-3-17 16:47     标题: AT27C4096 55JU
dear xgecu team
AT27C4096 55JU Could you add the plcc version of the above material?
作者: Albano.Matos    时间: 2022-3-17 18:37
dear xgecu team
mrt 发表于 2022-3-17 16:47
   As an user.....The T56, already have it there ( latest version 11.90) it uses a pin to pin 44 pin PLCC-DiP adapter.
The TL866II , need you do a 'trick', you should select the already there 40 DIP version, but also use a special adapter
Plcc44 dip40 adaptador/adaptador de conversor ic socket para tl866a tl866cs tl866ii plus ou outros programadores universais|Calculadoras| - AliExpress
As you may imagine, with an 40 pin  Dip main socket , you need a conversion socket from the PLCC44, and you are lucky if you buy it already . Be aware of jumpers positions :-)
Hope it helps You
