I noticed that the ATmega8U2, ATmega16U2, and ATmega32U2 MCUs are available for the T56 programmer, but are not currently enabled for the TL866-II+.
Can these MCUs please be enabled to be programmed with the TL866-II+ (both ZIF socket as well as ICSP port)? They should use the same programming algorithm as other Atmel AVR MCUs and should easily fit in the ZIF socket with the standard TQFP32 to DIP32 socket adapter.作者: admin 时间: 2022-3-4 10:32
TL866II can not support them.作者: serisman 时间: 2022-3-6 07:07
Can you clarify why you don't think TL866-II can support these?
The datasheets seem to indicate that the parallel and serial programming algorithms are identical to other Atmel MCUs that are already supported by the TL866-II. The only difference are in the pinouts, device ID, and config/fuse bytes.作者: admin 时间: 2022-3-6 07:36
