标题: ATMEL AT45Dxxx support [打印本页]
作者: Wacholek    时间: 2022-1-20 06:28     标题: ATMEL AT45Dxxx support
I just bought your T56 programmer. It is great but it lack one component support I need.
Would you consider to add support for AT45DXXX memory in PLCC32? They are the same as AT45DBXXX but when AT45DB are 3.3V AT45D is a 5V.
I made an adapter for external 5V VCC and my AT45D021 (PLCC32) works great, so it would be great to just to add AD45Dxxx 5V support on the next Xgpro. That would make my setup a lot more straightforward.
Best regards,
Chris
作者: admin    时间: 2022-1-20 10:45
回复 1# Wacholek
   OK
