标题: Microchip AT89LP52 support - please add [打印本页] 作者: DDTech 时间: 2022-1-10 17:31 标题: Microchip AT89LP52 support - please add
Hi
Current version (TL866ii - V11.80) does not support AT89LP52
AT89LP52 doesn't support parallel programming and can only be programmed via ICSP port
AT89S52 are supported vis ICSP port, but does not work with AT89LP52
Any work-arounds?
Can you add AT89LP52?作者: DDTech 时间: 2022-1-14 20:38
Please add Microchip AT89LP52
Datasheet to big to attached
Link to microchip:
https://ww1.microchip.com/downloads/en/DeviceDoc/doc3709.pdf作者: DDTech 时间: 2022-1-21 22:13
BUMP
Admin - please advise
Can you add AT89LP52?作者: admin 时间: 2022-1-24 12:25
