标题: New Logic Test - 74188 Vector Table [打印本页]
作者: yovish    时间: 2021-12-25 03:02     标题: New Logic Test - 74188 Vector Table
The test was performed on the K155RE3 (256-bit, 32x8bit words PROM, open-collector outputs, analogue SN74188N) chip from IC/Microchip USSR (now Russia).
This IC is a PROM (Programmable Read Only Memory), so general testing only makes sense for a blank/clean, non-programmed chip. Because after programming, each chip can have different contents.
In the unprogrammed state, a low voltage is generated at all outputs of the 74188 microchip (74S188).
图片附件: 74188 (Blank) - Logic Vector.jpg (2021-12-25 02:59, 510.56 KB) / 下载次数 13526
http://forums.xgecu.com/attachment.php?aid=1112&k=72b8b2bbe5a765a11441f7c073ad4be7&t=1795497150&sid=DqmxPP
图片附件: 74188 (Blank) - Logic Test.jpg (2021-12-25 03:00, 327.84 KB) / 下载次数 12503
http://forums.xgecu.com/attachment.php?aid=1113&k=cf6cdbff8404a227ffcf78b077970336&t=1795497150&sid=DqmxPP
图片附件: K155RE3 (SN74188N).jpg (2021-12-25 03:00, 589.09 KB) / 下载次数 13577
http://forums.xgecu.com/attachment.php?aid=1114&k=a5d7f29bb548f85db86746d40200a9b2&t=1795497150&sid=DqmxPP
附件: TI 54-54S-74-74S Programmable Read-Only Memories.pdf (2021-12-25 03:01, 366.25 KB) / 下载次数 9927
http://forums.xgecu.com/attachment.php?aid=1115&k=82a9b2846c7688714e5ae9f2129801f7&t=1795497150&sid=DqmxPP
附件: DM74S188-NationalSemiconductor.pdf (2021-12-25 03:01, 119.89 KB) / 下载次数 8109
http://forums.xgecu.com/attachment.php?aid=1116&k=56a9f8cb5f5f170237532d8c2f55a223&t=1795497150&sid=DqmxPP
附件: 74188 (Blank).lgc (2021-12-25 03:01, 2.83 KB) / 下载次数 40023
http://forums.xgecu.com/attachment.php?aid=1117&k=ff70481965dbc5e3da97f2e65822ac9b&t=1795497150&sid=DqmxPP
作者: Victor87    时间: 2022-11-7 02:46
Testing for a blank/clean PROM К556РТ4 (82S126) (256x4) bits
82S126.lgc (8.06 KB)
附件: 82S126.lgc (2022-11-7 02:45, 8.06 KB) / 下载次数 38745
http://forums.xgecu.com/attachment.php?aid=1541&k=4903f770dea335a6903eaa2fef68ab0b&t=1795497150&sid=DqmxPP
