标题: Please HELP me with Sharp LH28F320BJE-PT [打印本页] 作者: ancc78 时间: 2021-11-13 14:03 标题: Please HELP me with Sharp LH28F320BJE-PT
Hello.
I have Sharp LH28F320BJE-PT
Flash Memory 32Mbit (2Mbit x 16/4Mbit x 8). I can read it, I can erase it, BUT i can't programm it.
Here is my log
APP Version : 11.60 Model : TL866II Plus
Device : LH28F320BJE-PT @TSOP48
Pins Detected Passed!
ID: 0x00B0 00E2......OK!
Programming FLASH ...
Programming ...Failed
I've tried different IC types and find out that if I select LH32F800BGE-B (512Kbit x 16). I can programm the first 512Kbit of this flash and I've checked, the data is OK.
Please help me!作者: Albano.Matos 时间: 2021-11-13 18:27
Hello.
Flash Memory 32Mbit (2Mbit x 16/4Mbit x 8). I can read it, I ...
ancc78 发表于 2021-11-13 14:03
Hello,Please post the adapter you are using, V1base, V2 base, other?
Carefully handle the connection of pins and socket pins.
First 512kbits is normal . so bad pins is A18/A19 address pins ?作者: ancc78 时间: 2021-11-14 16:09
I've checked several flash chips. I think this is can't be a adress pin problem, because can read flash wih any problem. Test for pin connection shows no error. Also, I get programm error immediatly when starting to program. I also noticed, that LH28F320BJE-PT and LH32F800BGE-B have different algorithms. The first uses Flash16bit , and the second NorFlash. May be this is the problem?作者: ancc78 时间: 2021-11-17 14:06
Hello. Is it possible to solve my problem?作者: ancc78 时间: 2021-12-6 22:56
Hello. I've checked v.11.70 and the problem still exists. Can you tell me if this problem will be fixed next version, or I have to go and buy another programmer?作者: admin 时间: 2022-1-4 16:49
