标题: Problem with free space check in software [打印本页]
作者: STALKER_71    时间: 2021-9-23 14:49     标题: Problem with free space check in software
Hi, if i read emmc dump, software always check available free space. But if you need to read only 1gb and IC have 64gb software always checks whether 64GB is free and if not, then it does not allow reading the dump. Correct this bug please.
作者: admin    时间: 2021-9-23 15:00
回复 1# STALKER_71
Yes, when reading, check the available space of the disk. It is judged based on the chip capacity. I will modify it.
作者: STALKER_71    时间: 2021-9-24 02:33
Thanks! It's great.
