标题: TL866II Plus 电压设置 [打印本页] 作者: nomis 时间: 2021-9-9 19:37 标题: TL866II Plus 电压设置
Can you reply to my email!I send an email to the mailbox: 532007590@QQ.com
There are also SMS cell phone numbers from Pakistan.作者: admin 时间: 2021-9-10 13:45
Hello Admin, thanks for the reply my question was TL866II Plus have voltage setting for microwire eeproms 93cxx ?i was attached photo on email for better understanding of my question !
https://ibb.co/M9ZJz4M
https://ibb.co/xs26GfS
Thanks.作者: admin 时间: 2021-9-10 17:24
回复 3#nomis
none of this function, the operating voltage range of 93C is very wide, which is generally unnecessary作者: nomis 时间: 2021-9-10 21:08
I have another programmer which not read in circuit when it is on 5v "without removing eeprom from board" so i select voltage to 2.8v and it read write good .
