标题: Bad blocks after programmed firmware F59L1G81MA and F59L1G81LB [打印本页] 作者: ghostpvv 时间: 2021-8-25 23:33 标题: Bad blocks after programmed firmware F59L1G81MA and F59L1G81LB
The chip F59L1G81MA and F59L1G81LB is programmed and verifyed without errors.
But when doing check "NAND Bad Block Check" - there are always present bad blocks.
After cleaning "Erase", checking "Blank check" and "NAND Bad Block Check" - there are no bad blocks.
I tried different firmware and several chips F59L1G81MA/F59L1G81LB (there are no errors on the chips).
Adapter NAND08 modified.
Is there a bug in the programmer software for this chip?
