标题: What to select to program PALCE22V10H ? [打印本页] 作者: dceng41 时间: 2021-8-20 08:17 标题: What to select to program PALCE22V10H ?
I have a new TL866II+ and some Lattice PALCE22V10H chips. I See that the IC select menu have GAL22V10's B, C, D. Which one is most compatible ? Should I use the lowest possible programming voltage selection ?作者: admin 时间: 2021-8-20 12:49
