标题: 4049 and 40106 corrected test vectors [打印本页]
作者: tzok    时间: 2021-8-8 19:43     标题: 4049 and 40106 corrected test vectors
Test vectors for 4049 and 40106 in the current version (11.20) are wrong, correct ones should look like this:
作者: yovish    时间: 2021-8-8 22:03
回复 1# tzok
Yes, I know that and I have provided this information before on this forum.
http://forums.xgecu.com/viewthread.php?tid=320&extra=page%3D1
http://forums.xgecu.com/viewthread.php?tid=287&extra=page%3D1
I thought that the new version of the software would include a revised test version, but it didn't.
作者: admin    时间: 2021-8-9 10:30
回复 2# yovish
Yes fixed in the next version
作者: yovish    时间: 2021-8-11 05:55
Thank you.
作者: gigglebok    时间: 2021-10-10 20:15
40106 still not fixed in 11.30, Pin 12 Line 1 should be H.
Also 4016 does not verify, I need to use 4066 logic table instead. They are the same pinouts.
作者: admin    时间: 2021-10-11 10:52
回复 5# gigglebok
The last version missed the update, replace this file in the installation folder
Logic.lst (80.74 KB)
附件: Logic.lst (2021-10-11 10:52, 80.74 KB) / 下载次数 78347
http://forums.xgecu.com/attachment.php?aid=958&k=09326619c9ad4f61a13357b91dda5928&t=1793649590&sid=n5no9W
作者: yovish    时间: 2021-10-22 15:51
Improved logic tests of 4049 and 40106 chips are already available in the program version v11.50.
